PCV question
Old Jun 6, 2003 | 12:08 AM
Smoke_Ford's Avatar
Default PCV question
First of all, I did a heads/cam swap, I got rid of EGR and AIR. So what tubes do I need to take off the car, and what is the little tube coming off the back of the driver side valve cover? One more thing, what are the 2 hoses coming off the back of the intake for? Thanks.
Old Jun 6, 2003 | 12:45 AM
jmX's Avatar
jmX
Default Re: PCV question
EGR doesnt have any "tubes" besides the metal one that goes to the intake manifold that you very obviously removed already.
With the air stuff you can remove the hoses that went to the air system, it should be obvious since the hoses go to nothing now.
The 2 hoses off the back of the intake are:
1) the big one...this goes to the brake booster
2) the small one..this goes to the AC vents inside the car
The tube on the back of the drivers side valve cover is the PCV.
