whats the difference between a 99 block and an 01-02 block?
Old Oct 5, 2007 | 06:09 PM
Snyper's Avatar
Default whats the difference between a 99 block and an 01-02 block?
I might be getting a 99 LS1 engine and plan on modding it for my RX7 and was wondering how the block itself is different. I will be changing the heads/intake cam..pretty much everything up top including the rod bolts...just wondering how good the bottom end is.
Old Oct 5, 2007 | 10:04 PM
SoCal01z28's Avatar
I've read that the oiling system is worse on the older blocks(98-00), that and the cylinders aren't as thick, with that being said I swapped a 98 block/crank i had laying around into my 01. I don't think the worse oiling setup is anything that'll kill a motor.
Old Oct 5, 2007 | 11:46 PM
Thule's Avatar
uhh its the otherway around, 99+ have the thicker sleeves, and better oiling system
Old Oct 5, 2007 | 11:47 PM
Snyper's Avatar
Your thinking of the 98 specific block..I meant 99-00 and 01-02 they revised the cyl. walls and oiling on the 99 and up block.
Old Oct 6, 2007 | 01:23 AM
Jeff@TotalPerformanceEng's Avatar
01+ have slightly thicker sleeves, machined windows cast into the block at the bottom of the cylinders, and a few other things...
Old Oct 6, 2007 | 02:49 PM
Tainted's Avatar
only ls6 blocks had the windows for "bay-to-bay" breathing.
there walls were no thicker from 99-02, only the 98 block was thin and had a slightly less effective oiling system. Theres nothing different from 99-02 period unless its the ls6 block and even it offers no hp gain. Its actually weaker because its less solid material anyhow.
Old Oct 6, 2007 | 04:01 PM
SoCal01z28's Avatar
did you read my post?
