View Poll Results: Piston to Valve Clearance Technique Poll
Don't Mess With Texas
5
1.98%
Our state will kick your state's ass
38
15.02%
Republic of Texas
4
1.58%
Bigger Than Most Countries
10
3.95%
Lone Star State
2
0.79%
Got Oil?
0
0%
Home of the Fastest Dragstrips
4
1.58%
The Promised Land
5
1.98%
Home Of The Fast Cars And Beautiful Women
22
8.70%
Where Everything is BIGGER and BETTER
14
5.53%
350
0
0%
355
2
0.79%
360
1
0.40%
365
4
1.58%
370
0
0%
375
1
0.40%
380
2
0.79%
390
1
0.40%
395
2
0.79%
400
2
0.79%
405
1
0.40%
410
0
0%
415
0
0%
420
0
0%
425
1
0.40%
4GET IT
5
1.98%
NONE 4 U
0
0%
GET SUM
4
1.58%
GREGO 1
0
0%
GOTCHA
2
0.79%
1 BD TRK
6
2.37%
SEE YA
4
1.58%
98
3
1.19%
99
0
0%
00
4
1.58%
01
8
3.16%
02
24
9.49%
June 7th
16
6.32%
June 21st
8
3.16%
Fajitas
19
7.51%
Hamburgers and Hot Dogs
13
5.14%
Yes I use a solid lifter when checking piston to valve clearance.
9
3.56%
No I do not use a solid lifter when checking piston to valve clearance.I use a Hydraulic lifter and "checking" springs
6
2.37%
I do not check piston to valve clearance.
1
0.40%
Voters: 253. You may not vote on this poll
Old Jun 7, 2003 | 01:55 PM
Bink's Avatar
Default Piston to Valve Clearance Technique Poll
Old Jun 7, 2003 | 02:15 PM
-Joseph-'s Avatar
LSxGuy widda 9sec Mustang
Default Re: Piston to Valve Clearance Technique Poll
I use checking springs, with an adjustable pushrod set to 0 lash. Then I use a dial indicator to measure the clearance. Much easier than pulling a head and claying, and prob a whole lot more accurate.
Old Jun 7, 2003 | 05:46 PM
Bink's Avatar
Does this actually measure piston clearance or valve opening from the seat??
joel(Bink)
Old Jun 7, 2003 | 07:45 PM
felton316's Avatar
If you bring the cylinder to TDC and without a spring let the valve rest on the piston, measure that with the dial indicator. Then use the check spring and measure the valve when its totally open, then subtract the two numbers to get the differenc. The answer will be how much travel you have until impact with piston.
Old Jun 7, 2003 | 10:07 PM
Larry's Avatar
You will get less clearance on the overlap stroke. You can check TDC but I have never seen less clearance here than on the overlap stroke.
Old Jun 7, 2003 | 11:36 PM
-Joseph-'s Avatar
joel(Bink)
I measure intake valve clearance ~10deg after TDC on the intake stroke, and exhaust valve clearance ~10deg before TDC during the exhaust stroke. I don't actually zero the dial indicator when the valve is closed, I wait to zero it until the valve is at its closest point to the piston. If you wanted to, you could measure allot of things with dial indicators, they are a great tool to have.
Old Feb 8, 2008 | 07:32 AM
The highlander's Avatar
Care to post which tool should be bought? where to buy the checking springs?
How much does the lifter colapse w/o oil pressure?
Thanks
Old Feb 8, 2008 | 11:52 AM
PREDATOR-Z's Avatar
Dial indicator, light springs, modified (solid) lifter, dial indicator, degree wheel.
Measure 10* BTDC on intake and 10* ATDC on exhaust
Old Feb 8, 2008 | 03:23 PM
Russ K's Avatar
On a G5X3 114 LSA camshaft, the intake opens at ~6* BTDC @.050 lifter rise. The exhaust closes at ~4.5* ATDC @.050 lifter rise.
So the intake PTV should be checked at TDC & 10* ATDC. The exhaust PTV should be checked at 10* BTDC & at TDC.
Russ Kemp
Old Feb 9, 2008 | 02:41 AM
PREDATOR-Z's Avatar
At TDC both valves are closed so why measure there??
Old Feb 9, 2008 | 06:42 AM
vettenuts's Avatar
Both methods, one to check and one to verify my measurements.
Old Feb 9, 2008 | 10:12 AM
Bill Bowling's Avatar
Thanks
Summit has the kits:
http://store.summitracing.com/egnsea...rdSearch#rstop
I need to buy one myself. I need to check clearance on my Dart 205, .040 head gasket and my current cam.
Bill
Old Feb 9, 2008 | 04:05 PM
Russ K's Avatar
I'm referring to TDC exhaust stroke, not TDC compression stroke.
Russ Kemp
Old Feb 10, 2008 | 04:20 PM
RZRSEDGE's Avatar
I voted Get Sum. Sounds like the best technique to me!
Old Feb 10, 2008 | 05:18 PM
Ryan02SS's Avatar
I do the same but normally start 20*BTDC and 20* ATDC. I made my own checking springs that will compress long before the plunger in the hyd roller lifter will compress especially if it is pumped up.
