Trex & 1.8 rockers
Old Oct 9, 2007 | 12:03 AM
Guacamayo's Avatar
Default Trex & 1.8 rockers
What do you think about going 1.8 rockers with a trex? I know flycutt is a MUST and new lifters would be a good idea, already got 921 comp spring kit and 7.400 prods
TREX cam (1.7 rockers) 242/248 - .608/.612 - 110 lsa
Got the formula = lift x (new rocker) 1.8 / (old rocker) 1.7 and these were my numbers
TREX cam (1.8 rockers) 242/248 - .643/.648 - 110 lsa
What do you think about the lift? Any recommendations? thanks
Old Oct 9, 2007 | 12:14 AM
blueeyeddevil141's Avatar
I think, no. to steep of a ramp rate for a 1.8.
Old Oct 9, 2007 | 05:01 AM
vettenuts's Avatar
Beside a lot of deflection in the pushrods (which will negate your newly found lift) I think you will finish off your stock lifters.
Old Oct 9, 2007 | 08:16 AM
Guacamayo's Avatar
I could change lifters, do you still think I will get them finished out as the stock ones? thanks
Old Oct 9, 2007 | 08:46 AM
teke184's Avatar
its just not worth it...and likely not even possible.
the physics behind the geometry of the setup would prevent it.
and in all honesty...the added lift wouldn't make THAT much of a difference. you'd need some serious heads to take advantage of that flow.
Old Oct 9, 2007 | 09:17 AM
LS1Formula01's Avatar
ramp rate on the cam itself is too extreme for 1.8. even thunder racing doesn't recommend 1.8 rocker.
Old Oct 9, 2007 | 09:43 AM
hellbents10's Avatar
LS1Tech Sponsor
Just go with lsk lobe if you want that much lift.
Old Oct 9, 2007 | 10:01 AM
PREDATOR-Z's Avatar
No way Jose !!!
Old Oct 9, 2007 | 02:51 PM
Mexican Tlacuache's Avatar
Talking
Originally Posted by PREDATOR-Z
No way Jose !!!
lol, hey Guacamayo dont search the noise to the pork skin!!!!, in spanish: no le busques ruido al chicharron!!!!
Good Luck!!!
Old Oct 9, 2007 | 05:36 PM
Guacamayo's Avatar
Thanks everyone
