987 spring question
Old Feb 1, 2003 | 06:40 PM
12secondWS6's Avatar
Default 987 spring question
Just wondering if the stock rockers clear the 987 dual springs???? Or if you have to clearance them.
Old Feb 4, 2003 | 12:15 AM
Scalpel's Avatar
Default Re: 987 spring question
They clear just fine.
Old Feb 4, 2003 | 12:38 AM
jmX's Avatar
jmX
They will clear as long as you use a certain style retainer. There are some retainers you can use with a 987 that will require you to dremmel the rockers, and there are some that won't, so the spring itself isn't the issue.
Old Feb 4, 2003 | 11:18 PM
2001CamaroGuy's Avatar
If you get the retainers Thunder Racing sells, they will work fine. I installed them on my heads and I am very happy with them.
