first heads/cam install...is 2 days enough time?
My first.
Easy going really and I changed the oil pump too.
Putting header bolts back on, I cross threaded the #8 bolt
Have everything you need
Clean out the head bolt holes extremely good
Also, read up on the swap, and print out the how-to just so you have a reference.
Have a magnetic bolt grabber.
Put a large sheet under the car to catch **** you drop and make it easy to see.
Have lots of light.
Start early, work hard but steady - no beer til after.
Use air tools if available.
Don't remove the condenser, you can rotate it out of the way.
Have a helper to clean parts as you remove them.
Take a few pics for reference.
Use some baggies, trays, etc. to organize certain parts (pushrods, etc).
Lift the car as high as you can and use extra jackstands.
A weekend will be enough if you do these things and don't have to make too many unexpected parts runs.
Good luck!
for me, the worst part of my intall was getting the pulley on and off. we broke 1 pulley puller, so i went and bought a beefy one and it came off (90 minutes of swearing and giving in to buying another tool) and then putting the pulley back on. we didnt have a press, so we used a plank of wood and a mallet to "tap" it on, just to insure you dont strip the threads if your using the meathod of backing the pulley on with the old bolt. good luck and take your time
