Assembling
Old Oct 15, 2007 | 01:22 AM
blueeyeddevil141's Avatar
Default Assembling
New motor. Any tips? I am about to start to assemble my forged 347 motor. Block up, any tips you guys can suggest?
Old Oct 15, 2007 | 11:59 AM
JPH's Avatar
JPH
cleanliness, check and double check all measurements/clearances and trq. settings. use plenty of assembly lube/oil where it is needed. good luck.
Old Oct 15, 2007 | 02:40 PM
Anything else?
Old Oct 15, 2007 | 03:35 PM
oz304's Avatar
make sure all threads are clean + lube up the bolt faces and threads where applicable before tightening,remmember to spread he ring gaps about 90deg apart from each other
to limit blow by.
Old Oct 15, 2007 | 10:56 PM
to limit blow by.
Thought it was 180......
What should I gap my rings at by the way? Gunna be seeing a 200 shot, and then 13.5 psi about 6months later....
