GM Cam
Old Feb 1, 2003 | 08:50 PM
zTrackerz's Avatar
Default GM Cam
What do you guys think of this cam???
Roller Camshaft “Gen 3” Showroom Stock Design
This hydraulic roller camshaft for RPO LS1 or LS6 was designed for showroom stock road racing. It requires the use of 2002 and later LS6 hollow stem intake valves P/N 12565311, hollow stem - sodium filled exhaust valves P/N 12565312, and valve springs P/N 125565313. It features .570" intake and exhaust lift, 251 degree exhaust duration at .050" and 239 degree intake duration at .050".
Technical Notes:
• Lobe flank is not symmetrical – for best torque set intake to TDC@105 degree and for best poer set intake to TDC@106.5 degree.
• Cam timing @ 0.050" tappet lift (timed @106 degrees intake to TDC)
• Exhaust opens @ 51 degrees and closes @ 20 degrees with duration at 251.
• Intake opens @ 12 degrees and closes @ 47 degrees with duration at 239.
<small>[ February 01, 2003, 08:51 PM: Message edited by: zTrackerz ]</small>
Old Feb 2, 2003 | 11:47 AM
RaNsOm's Avatar
Default Re: GM Cam
that is one of the BIGGEST cams I've EVER seen fo an LS1 <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" /> 251 dur@.05??? geeeeez
Old Feb 2, 2003 | 10:56 PM
DONAIMIAN's Avatar
Default Re: GM Cam
If I had a car with a built bottom end that could take spinning to 7000+ rpm I would do it. But I dont so I wont. BTW thats bigger than the ASA cam I think its the grand am cup cam or something like that, I dont feel like looking it up.
Old Feb 2, 2003 | 11:23 PM
zTrackerz's Avatar
Default Re: GM Cam
That's the Grand Am Cup cam..
ASA is 226/236 525/525 110lsa..
