MPG with Torquer 2
Old Oct 20, 2007 | 05:30 PM
2000KnightRider's Avatar
Default MPG with Torquer 2
Has anybody experienced shitty gas mileage with the instalation of their cam and their car being an A4? Ive noticed a huge difference after my head/cam install and tuning. I filled it up yesterday and drove a total of about 150 miles and its at 1/4 of a tank. Is there alot of fuel spent at first start-up and just tooling around town with no highway driving? My SES light is on and it says my Throttle Position Sensor is throwing the code. My O2 sensors are fine and just wondering if anybody has gone through this problem. My tuning was fine with a fuel/air ratio of about 13.
Old Oct 20, 2007 | 05:49 PM
brad8266's Avatar
For comparison my M6 with a similiar size cam and heads gets 13-14 MPG strictly city driving.
Old Oct 20, 2007 | 07:19 PM
black01_WS6's Avatar
I get right around 225-250 on a full tank of gas. So an auto would get a little less. It seems about right to me.
Old Oct 20, 2007 | 07:20 PM
RunNE1's Avatar
I am getting ~14-15 combined(mostly city) driving. But that is untuned. My scan is showing there is lots of room for improvement.
Old Oct 20, 2007 | 07:32 PM
transaman98's Avatar
how many of you guys are havin "some fun" while you are driving around though? or are you guys talking strictly puttin around?
Old Oct 20, 2007 | 09:36 PM
ls2 bait's Avatar
i get 16-18 mpg all city. depends on the tank. get 23 all day on the interstate.
Old Oct 20, 2007 | 10:19 PM
Snyper's Avatar
Ill trade you for a smaller cam if you want to.
Old Oct 20, 2007 | 11:58 PM
SoCal01z28's Avatar
same as me, im around 17 mpg half city half freeway with a lot of wot driving. once on the way to vegas i got 27mpg, something like 350 mpg+ to the tank
Old Oct 21, 2007 | 01:31 PM
mullenh's Avatar
What about the converter? did you change it too? or is it stock?
Old Oct 21, 2007 | 01:34 PM
dochall22's Avatar
My Mazda barely gets 30mpg and ur gettin 27 in a v8? Crazynessness!!!
Old Oct 21, 2007 | 02:05 PM
code4's Avatar
I assume you had AFR of 13 at WOT? high 14's are what you should see at cruise.
Old Oct 21, 2007 | 07:20 PM
My AFR is a straight line at 13 all the way across the dyno sheet and my stall is stock.
Old Oct 21, 2007 | 08:01 PM
ASkipper's Avatar
If you are throwing a P0121 code-insuffiect TPS activity that is your problem. When the computer sees this code it goes into some kind of fail safe mode. It will add extra fuel and the trans will shift through all the gears by 40mph. You need to move the max kPa of the MAP senor at idle up because the cam does not have as good of vacuum at idle as the stock cam.
Mine was getting around 13-14 mpg when I had this code now with good driving I am seeing 17-18 in city driving, with stock 3.23 gears of course.
Old Oct 21, 2007 | 08:05 PM
Phil'sC5vette's Avatar
it's not that cam that 's going to kill your gas mileage, It's your playing with the power that suck down the fuel
Old Oct 21, 2007 | 08:12 PM
Stang-Slayer's Avatar
I got a tqr v2.....and I was running around with a Jeff Creech tune for a while I was getting 8mpg on the hwy! lol.....I got a good tune by R.P.M. (Ryans Performance Machines) out of Raleigh and my gas miliage was great.....low 20's on hwy 15-16 in city....it would go less though if i was on it all day long though
Old Oct 21, 2007 | 08:15 PM
oneBADDz's Avatar
16-18 city, 23-25 highway with a lockup stalled A4
Old Oct 21, 2007 | 08:17 PM
therobman's Avatar
u have a stock stall o geeze just wait when i had 3.73's and a 3500 stall id get 160 to a tank and thats b4 the cam
Old Oct 22, 2007 | 12:11 AM
When MC Racing tuned my car I noticed the idle when startup is around 600-700. Should it be higher or is that because i have no stall yet?
Old Oct 22, 2007 | 06:33 AM
ASkipper's Avatar
I have my idle set around 850rpm with the engine warm,but I also have a 3800 stall. They could have it set low becuase you have the stock stall.
Old Oct 22, 2007 | 02:25 PM
KurtRardin's Avatar
Veteran: Marine Corps
My mileage is about the same as it was stock. I've still got the 3.42s though...and HATE them. I've got a hotcam, LTs, ORY, Hooker catback, LS6 intake, Vinci Tuner, Lid, yada yada... No pullies though.
I can get around 28 mpg with the air on max on the interstate, and maybe 16 to 18 around town.
