Heads/Cam Question.....Help me out
The downside to milling the head is that you lose more PTV clearance because you have to mill .007 per CC instead of the .005 per CC that you get with a thinner gasket or deck mill. With the cam you have you're going to be close on your PTVC, so take that into consideration. Milling 2cc will only cost you .014" in clearance though, so you will likely be fine either way.
I would recommend the thinner gasket over the head mill every time. In this case you will lose a little more clearance going with a .040 gasket, but it will give you optimal quench and better compression. I have unmilled ported 243's and a 232/234 cam with a .040 gasket and things are working quite well. I had actually considered milling the heads as well as the thinner gasket but decided to be safe and keep a little more PTVC.
