cam install question
Old Oct 21, 2007 | 08:11 PM
ls-lx's Avatar
Default cam install question
what is the common problem with something grinding in a ls1 after a cam swap? some piece will self destruct? Just heard of it happening but never found the explanation of what happened.
Josh
Old Oct 21, 2007 | 10:47 PM
brad8266's Avatar
Grinding from a cam swap is not common at all so there is no good answer for you.
Old Oct 21, 2007 | 10:50 PM
joshp14's Avatar
Make sure your gears are dot-to-dot, your PtV is within spec, and oil pump o-ring isnt damaged and your golden.
