Valve Spring Replacement Tips
Thanks!
...use a pen magnet when taking the Keepers off the valve.
...buy 16 pen magnets to keep your lifters up during the swap (most do not trust the plastic finger thing in the block that is designed to keep the lifters up while you have the cam out...
Make sure your air hose fitting for the spark plug doesnt have a schraeder valve in it otherwise you'll hook it up and realize there's no air coming out right about the time the valve drops!
Its a pretty easy job if you have the right tools, and it sounds like you do.
Oh, JmX, Great web site you have! Excellent write ups!
Good Luck
When you say you're using the TR tool, is that the More Performance tool? If so, do all of the back ones first in case the tool strips. Once you get those out of the way, an overhead compressor can finish the job.
