whats the issue?
Loud valvetrain on cold start sounds kinda like a slap then it goes away but I have alot of valvetrain noise still is it rockers or lifters and if I were to have a bad lifter how could I tell and is it possible to break a lifter at the bearing to where the needle bearings fall out and get into the oil
I have a stock cam but I was wondering if lifter ended up going south or not because I broke a rocker arm a while back and found roller bearings in my oil got them out and changed the rocker arm then about a week later I found a lone rollerbearing in my oil but it might be from the broken rocker arm a while back but this one looks a little bit smaller than a rocker arm bearing so I dunno but I figure if I broke a lifter then I would know pretty quick the car still runs the same and pulls as hard
