stroker guys in here
Old Jun 11, 2003 | 11:44 PM
kumar75150's Avatar
Default stroker guys in here
What are the highest dyno numbers you have seen from an all stroke/stock bore LS1/LS6 motor?
Seems to me that the bore produces most of the horsepower in a a big cubic inch motor.
Also, should a car with 4.125" crank and stock bore make about the same torque as a 427? Mainly, is stroke the only determinant of torque?
Old Jun 12, 2003 | 12:50 AM
BADFNZ's Avatar
Default Re: stroker guys in here
Bore generally has more to do with torque than stroke.
Old Jun 12, 2003 | 05:09 AM
StevieZ's Avatar
That's the 1st time I've ever heard that school of thought!
Old Jun 12, 2003 | 06:31 AM
2001 Pewter WS6's Avatar
Restricted User
The longer the stroke the more torque...
Old Jun 12, 2003 | 02:52 PM
kumar75150's Avatar
I am wondering because I have the same stroke as the superstroker guys (4.125" crank) but no bore.
I am only putting out 450lb ft of torque.
Old Jun 12, 2003 | 04:26 PM
383ss's Avatar
I'm putting out 448 TQ with a very mild set of heads and 10.3:1 compression. 382 Stroker.
Old Jun 12, 2003 | 05:01 PM
kumar75150's Avatar
Ya I'm worried cause I am putting out the same numbers as you with supposedly a very nice set of heads, a decent sized cam, and around 10.7 to 1 compression.
Old Jun 12, 2003 | 06:00 PM
StevieZ's Avatar
What do you call a decent sized cam?
Old Jun 12, 2003 | 09:33 PM
kumar75150's Avatar
228/234 595 607 lift 110lsa
I am not 100% sure on the lift numbers but its close.
I am going to try a 244/250 610 620 112 lsa cam
Old Jun 12, 2003 | 10:10 PM
Ragtop 99's Avatar
You need to look at your torque curve and not just peak torque. Strokers normally have 400+ ft-lbs over a wide rpm band w/o having to rev to the moon.
No. the extra cubes of the 427 should produce more TQ and HP accross the board. Midrange Torque will also be effected by head porting, cam selection, and header and exhaust size.
Old Jun 12, 2003 | 10:25 PM
kumar75150's Avatar
Whats weird is that I lost 9hp when I went to 1 7/8" headers and a full 3" exhaust on the same dyno but on different days.
Old Jun 12, 2003 | 10:28 PM
BADFNZ's Avatar
I was reffering to boring as opposed to stroking. My mistake
Old Jun 13, 2003 | 12:20 AM
Fly By's Avatar
whats it makin for power?
Old Jun 13, 2003 | 12:33 AM
kumar75150's Avatar
It did 464hp, 453tq with TPIS headers, Borla Stingers.
Then it did 455hp, 452tq with Cartek 1 7/8" headers and Stainless Works 3" exhaust.
BTW, this is on a 2002 Z06. Heads were brand new LS6 castings ported and flowed around 315cfm at .600.
Old Jun 13, 2003 | 01:58 AM
bdawg/98mechamta#9's Avatar
dont bitch look at my sig !!
Old Jun 13, 2003 | 02:05 AM
kumar75150's Avatar
Dude if I recall right, you have a baby cam in there. Seems to me like these Lunati strokers dont make more peak horsepower than a regular heads/cam car unless you try a much bigger cam to utilize the extra cubic inches.
The cam I currently have is designed for heads/cam or cam only cars. I will report back when I try my new cam.
Old Jun 13, 2003 | 02:18 AM
kumar75150's Avatar
Also, how much do you think I can safely spray my Lunati motor? Remember the LS6 block has not been bored out at all.
I was thinking upto a 200 shot will be ok.
Old Jun 16, 2003 | 05:27 PM
kumar75150's Avatar
ttt
So does anyone have an alternative to the LS6 intake? Should I get the guy that ported my heads to do my intake?
Old Jun 16, 2003 | 05:35 PM
silent1's Avatar
I'm building a similair set up so I'm curious as to how high you rev with that long of a stroke? I'm going with a 246/246 600/600 112LS cam. I'm hoping to be done by the end of the month, it's just that everything seems to be on back order.
Old Jun 16, 2003 | 05:36 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
If you have a 4.125 stroke I would look at doing a new cam on a 114 LSA not a 112.
PSJ
