LS1 Supercharged 383
Old Oct 26, 2007 | 09:43 AM
RALLDU's Avatar
Default LS1 Supercharged 383
Looking to do a huge overhaul on my engine over winter. Right now my set up is as follows.
Stock lower end. Custom Ground comp cam 228/236@0.50 575/590 112lsa
85mm slp mass,ported polisher throttle, accel 30# injectors, patriot 1.7 adj shaft mounted rockers, double rollers timing chain, comp magnum lifters, chromemoly pushrods, stage 3 ported polished factory heads with 600 lift springs comp tit. retainers and manley racemaster valves in 2.020 ex 1.575, hooker long tubes.
Want to either install a 383 stroker kit, or buy a short block. And also looking to install a roots type blower/supercharger.
In looking for a realiable set up, but realy dont want to trash all the uppers i already have, cause its looking like some money so i want to try to and keep some of what i have.
Any Ideas.
Old Oct 26, 2007 | 09:47 AM
Sharpe's Avatar
I've heard some very well-known people on here say to go 370 for FI, not 383. I know nothing about anything, though. Something about better bore to stroke ratio for boost or whatever.
Funny thing is, the 373 Eagle kit can be had from eBay for like, nothing as far as stroker kits go.
Old Oct 26, 2007 | 10:27 AM
RALLDU's Avatar
Thanks for the input, ill check it out.
Old Oct 26, 2007 | 10:37 AM
99mongooSS's Avatar
now is a 370, an all bore ls2 or an all stroked ls1?
Old Oct 26, 2007 | 12:26 PM
Sharpe's Avatar
Again, I'm just regergitating info with a warning that I know nothing. I can only dream of FI until I somehow get another job where I make real money. Like, counterfitting.
The kit i spoke of, which has been discontinued and that's why its so cheap, is an old LS1 stroker kit. It comes with a crank. I just was throwing it out there without thinking that it might not work the same as the magic 370 I hear about on here. Sorry, forget i mentioned it.
Old Oct 26, 2007 | 12:53 PM
BadgeZ28's Avatar
Dished forged pistons are mandatory. Your heads are smaller chamber and you need to get down to around 9/1 to run much boost.
Old Oct 26, 2007 | 03:16 PM
99mongooSS's Avatar
EPP said a 346 would be fine to supercharge. In fact they do more 346 procharged build than anything else I believe. 9.5 is what ive been told is the magic number so that you still have low end grunt to get the supercharger spinning. Im in the beginning stages of my build.
Old Oct 26, 2007 | 03:18 PM
99mongooSS's Avatar
you can get away withyour factory crank if you dont want mor than 7-800rwhp. but your cam is gonna have to go.
Any Ideas.
Old Oct 26, 2007 | 03:21 PM
ls1leadfoot's Avatar
buy a big block and save a couple thousand.....
Old Oct 27, 2007 | 11:46 AM
RALLDU's Avatar
so if i went with a 383/373 kit low compression pistons i would be able to use the heads i have. ok what kind of cam would i be looking at to match a roots blown/supercharged 383/373.
thanks for the info so far
Old Oct 27, 2007 | 07:54 PM
quiet_storm98's Avatar
the 370 is the iron 6.0L truck block, it is fairly cheap and works great for boost
Old Oct 28, 2007 | 06:14 PM
RALLDU's Avatar
ok, say i buy a 6.0l truck block install my upper end and a roots type blower, would this need lower compression pistons or would this setup work.
thanks
Old Oct 29, 2007 | 02:00 PM
Andrew1989's Avatar
I wouldn't imagine you would be able to fit that big of a roots blower on top an an LS1 in an fbody. Look into the work people have to do to get them to fit. The D1 procharger has been a proven blower for the LS1 for quite some time now. It will make big numbers with a forged motor.
Old Oct 29, 2007 | 07:55 PM
yup there aren't many roots type blowers that will fit on our cars without alot of modification. You could just buy a procharger kit and not have to worry about getting it to fit, plus it will make alot of power if setup correctly
Old Oct 29, 2007 | 10:45 PM
Mike94ZLT1's Avatar
Think again
Old Oct 30, 2007 | 09:25 AM
RALLDU's Avatar
man that is one beautiful set up. if you dont mind me asking what kind of numbers we looking at here. so what all exactly was involved in your build. what kind of setup, top and bottom are you running.
sorry about all the questions, trying to pick your brain. and must say again, nice setup.
Old Oct 30, 2007 | 08:45 PM
ironexecutioner's Avatar
ill go even further and ask what blower, what psi and 2nd the "what kind of numbers" question! thanks
Old Nov 14, 2007 | 10:17 AM
RALLDU's Avatar
Anyone Out There Got Any Info On The The Perfect Supercharged Ls Based Motor.
Old Nov 14, 2007 | 10:33 AM
blueeyeddevil141's Avatar
Any Ideas.
You may want to consider a centrifugal blower....383+roots=LOTS of torque=no traction.
Old Nov 14, 2007 | 10:36 AM
It seems like you'd be able to see that blower peeking out of the hood if you looked from outside the car.....
