Car doesnt crank?
Old Oct 26, 2007 | 11:05 PM
1999ssls1's Avatar
Default Car doesnt crank?
I finally got my car put back together and drove it probably 20 miles today and was running like a champ. I cut it off and went back to drive it about a half hour later and nothing. When I turn the key to the on position I get no power to the gauges and it the motor wont turn over. Its like my batterys dead, but I replaced it with another I had and still the same. I checked all the fuses and test lighted a few power sources and all are good. The headlights and brakelights work. The power windows, radio, blinkers and gauges do not. Anyone had this problem before? Any ideas?
Old Oct 26, 2007 | 11:21 PM
topdownTA's Avatar
From: Way Out In The Boonies Chasin' Hill Billies, North GA
I would say that you either missed a fuse, or possibly a bad ignition switch. Sounds like you're not getting power to anything that is keyed on with the ignition. This should hopefully give you a general area to look in. If you need wiring diagrams, I can set you up with some off of Alldata.
Old Oct 28, 2007 | 01:19 PM
topdownTA's Avatar
Any luck yet with the car?
