stripped cam retainer threads...
Old Oct 27, 2007 | 01:01 PM
Big Z's Avatar
Default stripped cam retainer threads...
so im installing my new cam, and i was told to be very careful to torque down the cam retainer plate, and while doing so it stripped the threads in the block on the very top bolt. the other three are in solid. what can i do to fix this? i dont want an oil pressure problem. thanks
Old Oct 27, 2007 | 02:01 PM
eallanboggs's Avatar
small bolt = low torque value!
Old Oct 27, 2007 | 02:43 PM
Weezzer's Avatar
Helicoil time!
The kit will run you near $100.
Old Oct 27, 2007 | 03:17 PM
vettenuts's Avatar
If the hole is blind, use a helicoil kit. Autozone has them for around $20.
