advice plz!
Old Oct 29, 2007 | 12:14 AM
01SOMSS!'s Avatar
Default advice plz!
so far i have
lid &k&n ,tb bypass,free ram air, ls6 maf, Lt's w ory, corsa,car came w/ ls6 manifold, other mods w/ no hp gains... pro 5.0, w/ lous short stick, bilstein shocks, eibach springs.
coming soon
410's
ported TB or nick williams 90 mm
underdrive pulley
TSP magic stick 3 cam 237/242, .603"/.609"
plus tune....
will i go through springs often w/ that cam?
anything else i should do? i am going to get the heads next summer.what numbers will I get with out the heads? any suggestions on parts to get or change are welcomed.thanks!
Old Oct 29, 2007 | 12:27 AM
TARZAN's Avatar
Well, unless you upgrade intakes, you won't be able to run the Nick Williams 90mm TB, for an LS6, a ported stocker should do just fine.
Also, avoid the 4.10's in you plan on launching the car, on a good set of sticky tires, they won't hold.
I may have over looked it, but I don't see a clutch listed. If you don't have one, its more than needed.
Are you looking for a 1/4 mile car? A corner carver? An all around fun DD?
-Will
Old Oct 29, 2007 | 12:45 AM
01SOMSS!'s Avatar
a cruiser that has *****. I want 400-450rwhp. i know i'll need the heads for that.
