ARP Studs please help
Old Jun 12, 2003 | 09:43 PM
SoCal LS1's's Avatar
Default ARP Studs please help
Can the stud kit be installed prior to setting the head on block, is there enough clearance to slide heads on. Or do they have to be installed with head on vehicle. Vehicle is 1998 Camaro Z-28
Old Jun 12, 2003 | 09:45 PM
Country Boy's Avatar
Senior Member
Default Re: ARP Studs please help
yes
Old Jun 12, 2003 | 09:54 PM
which one or do both work
Old Jun 12, 2003 | 10:18 PM
ttt
Old Jun 12, 2003 | 10:56 PM
Jason99T/A's Avatar
I can shift faster than you.
Install the studs before installing the heads. You have plenty of room.
Old Jun 12, 2003 | 11:01 PM
2001CamaroGuy's Avatar
yes....install the studs in the block, then install the heads. There is plenty of room and the studs will guide the heads into place.
note: remember to clay before you put everything together (p-to-v).
Old Jun 12, 2003 | 11:05 PM
Thanks for all the help highly appreciated
Old Jun 13, 2003 | 12:26 AM
malibu350's Avatar
when I did mine I had to put the heads on first then put the studs in....but I've heard people say that they did them with putting the studs in first...I just don't understand how with the heater core getting in the way on the passenger side
Old Jun 13, 2003 | 08:09 AM
Chris99WS6PWTMET's Avatar
Just installed head studs and then the heads 2 nights ago. ZERO problems. There is plenty of room in there. Didnt "look" like there would be, but there was.
Old Jun 14, 2003 | 11:53 PM
malibu350's Avatar
that's good to know next time I do them...
