g5x2 on a 114 +4
Old Oct 30, 2007 | 10:26 AM
cpt_bimes's Avatar
Default g5x2 on a 114 +4
Anybody run this LSA? I always see everyone running a 112.
How much different would this be compared to a 112? I want the 114 +4because of the better vaccum characteristics and wider powerband (not going 4.10's).
Would I have PTV clearance issues?
I still want it to hit like a good sounding cam and not like a wuss small baby cam.
Old Oct 30, 2007 | 10:42 AM
John02Hawk's Avatar
What are the specs of that cam?
Old Oct 30, 2007 | 10:44 AM
cpt_bimes's Avatar
232/240 .595 .608 112/114
Old Oct 30, 2007 | 12:41 PM
00Formula00's Avatar
Check with either Patrick G, Predator Z or the guys at LG... I'm not too sure but it should be fine, I have milled AFR heads and I was told the X3 would fit without PTV issues but I am still going to flycut to be safe...Stock Heads?
Old Oct 30, 2007 | 12:57 PM
PREDATOR-Z's Avatar
Cam only, no issues on X2 114, good M6 cam
Old Oct 30, 2007 | 12:58 PM
N4cer's Avatar
Most of the guys in my area prefer the 114 LSA on the LG cams. And no, you should have no PTV issues with the X2 on a 114 on stock heads.
Old Oct 30, 2007 | 01:39 PM
cpt_bimes's Avatar
yeah stock heads.
Should be around 405 rwhp on stock heads?
Old Oct 30, 2007 | 03:45 PM
What are your supporting mods, those will decide if you hit 400
Old Oct 30, 2007 | 05:01 PM
Da Swami's Avatar
What about running this cam with a set of aftermarket heads?
Old Oct 30, 2007 | 05:29 PM
chriswtx's Avatar
Old Oct 30, 2007 | 06:23 PM
Are you suggesting or asking?
Old Oct 31, 2007 | 12:01 AM
Da Swami's Avatar
Asking. Will there be PTV issues?
*cough* Like, say a set of Patriots *ahem*
Old Oct 31, 2007 | 12:45 AM
You should be ok unless you decide to mill a lot, I have 59cc chamber heads with the X3 cam and I am going to flycut to be safe...
Old Oct 31, 2007 | 01:21 AM
N4cer's Avatar
If going with aftermarket heads, get a custom ground cam to match them. I should've, and so should everyone else after I've learned about how heads and cam work together.
