Catch can set up?
Old Jun 13, 2003 | 07:42 AM
MYBLKSS's Avatar
Default Catch can set up?
Pulled the Tb the other day and took a look in the manifold filled with oil. Where can I get A catch can set? I know you can make them your self but I want something that looks clean. Any Ideas?
Old Jun 13, 2003 | 09:10 AM
MYBLKSS's Avatar
Default Re: Catch can set up?
ttt
Old Jun 16, 2003 | 09:14 AM
robertbartsch's Avatar
Try installing a Ls6 valley cover instead....mine seems to work great...
Old Jun 16, 2003 | 09:20 AM
Question: did the oil appear dhortly after you installed headers?
Old Jun 16, 2003 | 10:07 AM
MYBLKSS's Avatar
I didn't really notice it until I swaped the heads but i think the car has always had the problem becasue my old intake was pretty oily when I swapped it out.
Old Jun 16, 2003 | 10:52 AM
horist's Avatar
I was having a problem where on decel i'd puff out smoke... so I installed a catch can (I have the LS6 valley cover and PCV too...)
I bought some *I think* 5/16" ID clear hose, 2 barbed hose connectors with 3/8" connectors, and 1 Craftsman air/water seperator. Connected thtem all together and I collected about 1 thimble full of oil after 50 miles of very aggressive driving. Since then w/a combo of aggressive and normal driving (400 miles) i've collected about another 2 or 3 thimbles full...
I did heads/cam/headers at the same time as the LS6 PCV so the other stuff may have cancelled the positive affect of the LS6 PCV out... dunno, but I am still sucking up oil... but at least now it's not all getting into my intake
WHen I did mine I didn't really care if it was neat.. I mean it doesn't look bad, but you can seeit when you pop the hood. With this setup though you could easily hide the catch can... just buy black hose instead of the clear hose, and run longer pieces somewhere so you can hide the catch can...
