PTV checking, help
Old Oct 31, 2007 | 08:35 PM
blueeyeddevil141's Avatar
Default PTV checking, help
I am about to check my PTV and want to know is it okay to use my new gaskets to tighten down the heads, remove them to check the clay, then reuse them?
Old Oct 31, 2007 | 11:36 PM
snake charmer's Avatar
waht kind of gaskets are you using ? you could just use the old ones for the check and add in a slight safety margin .
Old Oct 31, 2007 | 11:38 PM
Nevermind, I am not unna even check it. I remembered I checked with a stock shortblock with this cam, and these pistons are -4cc reliefs...no need to.
