correct my research-torque rockers
Old Nov 3, 2007 | 08:17 PM
transfan0186's Avatar
Default correct my research-torque rockers
one of my rockers took a dump on me today. i run dual springs, mild cam. i believe i was told to torque these to 32lbs back when i installed the springs. Was I told the wrong torque specs? Everything i research on here says 22lbs. Is 22lbs for stock only?
Old Nov 4, 2007 | 10:56 AM
any experts?
Old Nov 4, 2007 | 11:01 AM
99 2500's Avatar
GM manual says to torque rocker arms to 22 ft lb.
Old Nov 4, 2007 | 11:53 AM
vettenuts's Avatar
22 lb-ft per below:
Old Nov 4, 2007 | 12:19 PM
Old SStroker's Avatar
22 lb-ft gives the correct clamping load with the 8 mm bolt and doesn't rip the threads out of the head. Increasing the clamping load about 45% with 32 lb-ft doesn't do good things.
Old Nov 4, 2007 | 02:11 PM
Geez..Thats not cool.. I can't believe I was told 32.. I've been driving it with 32-34lbs for almost 3000 miles now! Looks like another fix is on the way. Thanks for the help.
