are these trick flow pushrods for ls1?
Old Nov 4, 2007 | 12:50 AM
unclebens's Avatar
Default are these trick flow pushrods for ls1?
are these trick flow pushrods for ls1? http://store.summitracing.com/partde...w=1&N=700+150+
if not, what other affordable pushrods are out there.
ryan
Old Nov 4, 2007 | 01:04 AM
09CPTN's Avatar
They say universal for application, which is obviously bs. But yeah, i'm 99% sure that those are the specs for stock ls1 pushrods. Comp also makes a good set that won't break the bank.
Old Nov 4, 2007 | 01:51 AM
MJD's Avatar
MJD
I run trick flow rods. No problems with them here.
Old Nov 4, 2007 | 07:08 AM
vettenuts's Avatar
I run Trick Flow here as well, but you better measure before you order to verify your length.
