Connecting Rod Side Clearance Issues
I can physically slide the rods away from each other after being torqued down (15 lbs-ft + 60 degrees) and i can slide in a .022mm feeler gauge.
But then when i rotate the crank a couple times the rods pull together and the side clearance becomes 0...
how do i keep it around .018 - .022 mm???
