Compression check questions inside! Low on power?
So tonite I did a compression check.
#1cyl DS-205--this cylinder the spark plug looks wet almost shiney
#2cyl DS-190
#3cyl DS-185--this cylinder the spark plug looked slightly wet/shiney and some oil residue
#4cyl DS-190
#5cyl PS-190
#6cyl PS-185
#7cyl PS-190
#8cyl PS-195
So looking for advise. What should I check next to look for some lost power. The car does smoke in the upper RPM's and leaves out smoke on deceleration after getting on it. Car does burn the usual oil. The plugs usually dont look really bad or anything excessive.
Thinking I should pull valve covers and check all pushrods and reseal the roller rocker studs with blue loctite? when apart????? Give me a idea of where to go folks. I'm puzzled.
Bruce
__________________
2000 TR FRC
455rwhp/408rwtq H/C/I
11.31@124.22mph-1.575 60ft
4.10's, textralia, TSP/PRC,Fast 90/90LS2TB,M3 cam, Kooks LT's, SLP POYourneigbor edition catback, Chrome Z06/Weld draglites all around See my taillights in front of YOU!
http://www.reidonly.net/banners/banner-fartpipe.jpg
