Piston Ring Gap
Old Jun 17, 2003 | 01:48 AM
98 Silver Bullet's Avatar
Default Piston Ring Gap
Are stock piston rings from GM pre-gapped. If not, what are the gaps supposed to be? Also, how are the ring gaps aligned. For example. 180 degrees . Or does it even matter.
Old Jul 3, 2003 | 01:33 PM
robertbartsch's Avatar
Default Re: Piston Ring Gap
the SDPC catalog has two types (i) file fit, and (2) pre gapped...
...you should call them and ask, however...
