Cam
Old Nov 8, 2007 | 08:17 PM
blueeyeddevil141's Avatar
Default Cam
What is the biggest cam I can fit in a LS1 with stock heads and -4cc pistons....
Old Nov 9, 2007 | 01:57 AM
Any chance of getting .700ish lift?
Old Nov 9, 2007 | 06:02 AM
BlackScreaminMachine's Avatar
Internet Mechanic
Thats alot of lift, wow.
As for cam if you got slightly dished pistons, your options do open up, but I am no cam expert, I hope you find your answer.
Old Nov 9, 2007 | 08:01 AM
KONG's Avatar
Are you serious??? With a stock LS1 casting the maximum ceiling for lift should be .600. You have to look at the flow numbers of the cyl. head you are using and try and maximize that with the appropriate cam size. Bigger is NOT better. Do a search on this website and I guarantee you will rethink the whole .700 lift thing.....
Old Nov 9, 2007 | 10:17 AM
No, I know biggers not better, and I have done a lot of cam research, i'm already cammed....i'm just curious. And trust me, .600 is not max on a stock LS1 =]
Old Nov 9, 2007 | 10:18 AM
And yes, I know duration does play a gigantic part int how much lift a cam can have, I just need to know if a cam with .700+ lift can get in this motor, and run.
