Crane spring tool???
Old Nov 9, 2007 | 06:32 PM
1BADAIR's Avatar
Default Crane spring tool???
I just got the crane valve spring tool but it appears to be wrong. When the cup for the valve cover boss is in position the rocker bolt holes are only about half visable. I double checked the box and it is says its the LS1 tool. What does the small block tool look like.?Could it have been misboxed or are others having this issue too. BTW I have 243 heads
Old Nov 10, 2007 | 07:27 AM
vettenuts's Avatar
See post #10. I have used the plate both ways since some retainers fit differently in the plate.
Crane Valve Spring Tool
Old Nov 11, 2007 | 10:42 PM
Jrp1978's Avatar
You Want The Cutout Part Facing Up
Old Nov 12, 2007 | 06:36 AM
BlackScreaminMachine's Avatar
Internet Mechanic
I need that tool...... omg
Old Nov 12, 2007 | 07:02 AM
vettenuts's Avatar
I have actually used it both ways, with it down it works better on certain retainers than up.
Old Nov 12, 2007 | 07:51 AM
NOBR8KSS's Avatar
I had it upside down the first time I tried to use...
