LS6 heads for FI
Old Nov 10, 2007 | 05:06 PM
HTX's Avatar
HTX
Default LS6 heads for FI
i am buying new heads to go with my cam install.
i want a set of heads i wont have to replace when i go 408 or FI (havnt decided) are there better options (like AFR)?
I have seen LS6 heads on both FI and 408's thats why i was looking into LS6 heads. anyone have any input?
Old Nov 10, 2007 | 05:49 PM
chriswtx's Avatar
I'm running Texas Speed PRC stage 2.5 LS6 heads..Seem to work well so far. I've boosted to 15-16psi. Around 600miles on my new motor...My first choice if I had the extra $$$ would have been Trick Flow heads..Probably better for higher boost in the 18-20psi range...But the stage 2.5 with there larger valves seem to work well with boost...
