View Poll Results: which heads are the best
afr
136
46.26%
et performance
54
18.37%
other brand
104
35.37%
Voters: 294. You may not vote on this poll
Best Aftermarket Heads?
Old Nov 12, 2007 | 05:39 PM
SSCUSTOM6.0's Avatar
Default Best Aftermarket Heads?
what is the best aftermarket heads out there for a ls series stroker engine. whether it be a n/a egine or a boost engine.
Old Nov 12, 2007 | 05:40 PM
Soul TKR's Avatar
AFR gets my vote
Old Nov 12, 2007 | 05:41 PM
SS101's Avatar
afrs flow better under just about every condition
Old Nov 12, 2007 | 06:19 PM
LS1RedZ's Avatar
TEA makes some bad *** heads.. I have their Stg 2 LS6 heads.
Old Nov 12, 2007 | 07:30 PM
DONAIMIAN's Avatar
The be all end all head is the ETP canted valve.
Old Nov 12, 2007 | 09:37 PM
Vrbas's Avatar
I say ET just cause they are easier on your wallet and i've heard they flow well.
If you're not on a budget, it's a no brainer ---> AFR
Old Nov 12, 2007 | 10:46 PM
quiet_storm98's Avatar
umm actually etps are usually more expensive then afrs..both of them cost over 2k but the etps are usually a lil more
Old Nov 13, 2007 | 07:13 AM
BlackScreaminMachine's Avatar
Internet Mechanic
ETP or even a TFS head, they have been making some waves.
Old Nov 13, 2007 | 07:50 AM
N4cer's Avatar
I saw a lot of fast cars running the TFS heads at the shootout.
Old Nov 13, 2007 | 09:36 AM
tcr98taws6's Avatar
I have a set of out of the box TrickFlow 235's on my LSX454 and it threw down 625 RWHP running thru a Fast 90. Torque is HUGE under the curve, over 500 RWTQ at 3,500 RPM and peaking right at 580. Put a sheetmetal intake and that power goes up.
I'll take the TrickFlows.
Old Nov 13, 2007 | 10:16 AM
TXZ28LS1's Avatar
the AFR's!! but the trickflow heads have been making alot of power lately too!!
Old Nov 13, 2007 | 10:35 AM
CriminiSS's Avatar
Trickflows for the win!
Old Nov 13, 2007 | 12:17 PM
Vrbas's Avatar
Hmmm, i've been told they were cheaper
Maybe i'm thinking of a different set of heads that starts w/ "A"
Old Nov 13, 2007 | 01:25 PM
Evans752's Avatar
My vote Trick Flows
Old Nov 13, 2007 | 04:41 PM
3.4camaro's Avatar
Trick Flow.
Old Nov 13, 2007 | 08:40 PM
ExceSSive's Avatar
AFR...maybe I am biased...as that is what I am running. We will see after my 408 gets done.
Old Nov 14, 2007 | 09:04 PM
98_WS6's Avatar
Tricks flows are pretty good and inexspensive.
Old Nov 15, 2007 | 10:37 AM
code4's Avatar
For boost AFR's are def the best IMO. They have a thicker deck & will hold the head gaskets better.
Old Nov 15, 2007 | 01:34 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
+1 the only thing I've seen come close are the All Pro LSW heads. Between the two if I was on a budget I'd take the All Pros.
Old Nov 15, 2007 | 02:55 PM
3.4camaro's Avatar
Man I wish i was faced with a decision between All-Pro and ETP. Sounds like a good life.
