I could use some good help on a build
I am paired up with a built TH350, Shift kit, B&M Torkmaster 2800 Stall, 3.69 gears, I could go to back to 4.08 if need be.
I am not an engine guy, I know my way around and how to work on the normal things, but when it comes to building them up I dont know the pros and cons of what parts work well with others.
I would like to up the power some, I would like to make 400-450 RWHP
Right now I have
Dual Borla XR's 3.0 in/out, and an Xpipe all three inch pipe, no cats
I am using a fuel cell with a MSD 2225 inline fuel pump, Holley Regulator
Ported and De-Screened MAF
Fast 90mm Intake Manifold
Looking to go to 42# injectors, FAST fuel rails
I have a lot into the car and much work to do so I am on a budget, What would you do to meet my goals. Its not a DD but its a street car, mostly for weekend drives, show, and having fun. I was thinking about getting a set of LS6 heads and getting a port and polish, and a Thunder Racing cam for starters. Are the LS6 243 heads a good choice to get me there, if so what should I do to them and what cam should I pair them with.
What do you suggest?
I got a set of 317 Cast heads for free off of an LQ4, but I dont think I have a use for them
No porting needed?
Rockers?
Any cam suggestions, iv been looking at the Thunder racing cams but there are too many choices. But they have a package deal.
"Thunder Racing LS1 Cam Swap Package w/ Dual Valve Springs Includes:
- Your Choice of Thunder Racing Camshaft
- Dual Patriot Gold Valvesprings and Ti Retainers
- Thunder Racing Pushrods (7.400)
- Valve Stem Seals
- Additional spring options available below"
And I was thinking of going to the 3800 stall TCI StreetFighter/Super StreetFighter
