Help with pinging problem
Now that the cool weather has arrived I have a horrible ping under heavy throttle. Sounds pretty bad. I first suspected that I had a bad tank of fuel so I waited out on the tank and re-filled with good premium and it is still pinging. The car has been well maintained. Recent plugs (NGK TR55), injection cleaning, fuel filter.
Fuel pressure at the rail is 52psi with ignition on and 62psi running. Any ideas?
Some people run two tunes in their cars. One for Summer and a different one in Winter.
If you are pulling oil in to the intake through your PCV that can can cause pinging. An oil catch can could help there.
I bet there's a pressure drop and you aren't getting enough fuel. Your pump might be getting weak. Also, have you changed your fuel filter lately?
