Heads
Old Nov 16, 2007 | 10:29 PM
cdavis01's Avatar
Default Heads
What do u guys think that a set of 317 LS6 heads would give me without porting them?
Thanks guys
Old Nov 16, 2007 | 10:33 PM
quiet_storm98's Avatar
317's are 6.0 l truck heads, not ls6 heads. they are usually used for boost since they have a larger combustion chamber
Old Nov 16, 2007 | 10:39 PM
cdavis01's Avatar
Well i was jw, how much u think they would give without porting them?
Old Nov 16, 2007 | 11:00 PM
hard to tell..they flow better then your stock heads but they have larger combustion chambers which would bring down your compression and with an na motor higher compression is what you want. Honestly i wouldn't go through all the trouble of putting them on unless you plan on boosting your ride and even then it would be benificial to get them ported first
Old Nov 16, 2007 | 11:02 PM
cdavis01's Avatar
So basically they really wouldnt be worth putting them on?
Old Nov 16, 2007 | 11:21 PM
mullenh's Avatar
correct, don't do it
By Brett Foote | 2026-06-04 05:00:17
