Oiling differences..LS vs LQ9
My question to you guys is this...
Are there any oil differnces between the LS family motor and the 6 liter motors? I am pretty sure there isn't but I want to make sure I didn't miss anything.
Here is the other thing that is on my mind. I had ZERO oil pressure. Autometer reads ZERO and the scanner says -15psi at the factory sensor. I thought maybe the assembly lube was thinning the oil. So, I change the oil and the filter. Fire the motor and still ZERO oil pressure. The oil looked good, no flakes, no gunk, no chunks. I took the valve cover off and the head is BONE DRY. This tells me that the pump isn't working or the pick up tube is blocked. You would think that unless there is a squirrel stuck in the pick-up, I would have a little bit of pressure. Even a bad pump will give you something.
I wanted rack some other brains, to see if there is anything I missed.
Alright, go ahead, fire away!
Steve
Steve Demirjian
Race Engine Development
Oceanside, Ca.
760-630-0450
web: www.raceenginedevelopment.com/
e-mail: race-engine-development@***.net
good luck...
Grease? Vasoline? What is the best thing to pack it with?
