Suggestions for a mild H/C combo
The motor is bone stock and I was looking to give it some life while it was apart. I dont want to do any bottom end work, this will be a part time daily driver.
Any input would be appreciated.
If I were to do it again, I might go a tad smaller, 226/230-ish or even 224/228-ish and mill the heads a few CC's for higher compression or run thinner gaskets. And I'd go with a ported Fast 90 or ported LS2 manifold and 90mm TB.
As far as parts on the Blazer right now, a 3200 stall, Ram air, custom ecu. The truck will get tuned after I get a h/c. Custom headers, 3 in dual exhaust, I'm contemplating direct port though. I really havent done much.
