HELP :: Weird noise from engine :: VIDEO
Old Nov 19, 2007 | 09:38 PM
Wdpballer46's Avatar
Default HELP :: Weird noise from engine :: VIDEO
Well the other day I started my car and this click noise cam out of nowhere... (Its not the hissing in the beginning and end of the video) it seems to be only when i give it throttle, checked the oil and the levels are good. I thought it could be a pushrod or something but then again I'm just guessing so if anyone could help me it would be awesome.
Link to video
(sorry for the crappy quality)
Old Nov 19, 2007 | 09:39 PM
dochall22's Avatar
the hiss sounds like a problem too, you got a vaccum hose lose? broke?
Old Nov 19, 2007 | 09:40 PM
whats strange about the hiss is that i didnt hear it at all when i was filming the video...
Old Nov 19, 2007 | 09:56 PM
dochall22's Avatar
i found mine by taking a rag and laying it over certain spots and when the sound got quiter i new i was close1!!!!! lol one of my hoses got a hole in it and i just couldnt find it
Old Nov 19, 2007 | 10:05 PM
slmdLS1's Avatar
sounds like somethings loose in the valve cover. and the vacuum leak as well.
Old Nov 20, 2007 | 09:57 PM
guess i'll have to take them (or if i get lucky, one) off and see whats up. any ideas on how to go about the vacuume leak tho?
Old Nov 23, 2007 | 02:46 PM
got-a-ls1's Avatar
check the small hose coming from the pcv into the manifold behind the throttle body. Its a short line with a small bend in it. I know mine had a hole in it, its very thin and cheesy rubber. I just replaced it with a section of i believe 3/8 inch fuel line and its perfect. I could be many other lines but try that first because like i said the rubber is junk...
the noise sounds like possibly a rocker has gone south... hard to tell with just a video where the sound is coming from your just gonna have to start tearing or wait for something to break completely, which you shouldnt do... lol.
Old Nov 23, 2007 | 07:16 PM
badass99ss's Avatar
Grab a pieace of hose and stick it to your ear, move around the engine compartment and listen for a hiss.......old school
Old Nov 23, 2007 | 07:35 PM
98Camarod's Avatar
Sorry to dissapoint you fella, but that is the same exact noise that my collapsed lifters made. I was hoping it would be a bent pushrod or something, I wasn't that fortunate. It happened after my car had sat for about 3 weeks. I went and started it up, and there that wonderful noise was.
Old Nov 24, 2007 | 09:51 AM
99blancoSS's Avatar
I was going to say lifter or rocker
Old Nov 26, 2007 | 08:07 PM
thanks for all the help. i found out what it was and got lucky... it was just a loose header bolt. Still have the vacuum leak tho, ill have to search around for it.
Old Nov 26, 2007 | 08:26 PM
Travis99LS1's Avatar
the best way to find a vacuum leak is with brake or carb. cleaner....just spray it on anything that you think could be leaking..The idle speed will change when you spray around the leak..
