LS1 1.8 roller rockers
Gonna pick up some 1.8 roller rockers from ebay, the aluminum ones that can be found for about $300. Any ideas on those?
My car is a daily driver (look at signature) and just wanted to add a quick direct bolt on 15hp.
I have no clue what brand they are.
Also that most cams, if you decide to upgrade do not want you running the 1.8's, they are ground with a 1.7 rocker in mind.
this is a complete kit, which includes everything that you need besides valve springs. I recommend dual springs, either there #144832 or #144833-16 springs. They will also require there spring locators #144460-16 and new gm seals for there direct bolt in replacement.
before we button it up. I am going with the 1.8s so the geometry will change. AHA! I think you answered my question with a post you made on another thread. The process of shimming will determine the swipe and then you just get push rods to match the end result of the shimming.
