ASA cam swap trouble
The heads are off and every single intake valve kissed a piston. The two valves that were significantly bent had some decent marks in the pistons but I have not found any cracks yet. I thought I did and I about barfed all over the motor. I stepped away and then wiped the carbon a little more to see that it was a number stamped in the piston.
