Cam/head combo confusion
Old Nov 24, 2007 | 03:09 PM
SilverStingerSS's Avatar
Default Cam/head combo confusion
The car is a daily driver now leaving for the navy, so not for sure how much i will get do drive it. So debating on a mild set up. Car is a 6speed, 4:10s, built tranny, All bolt ons besides ud pulley and better intake manifold (ls1 intake) Been looking at the mamo cam just dont wanna be dissapointed in it, and was looking at stage 2 ls6 or 5.3 heads. Should i get the double roller timing chain and ported ls6 oil pump also? Just want a little bit of help on deciding. (ls6 intake manifold will be done with everything at the same time)
Old Nov 25, 2007 | 04:03 AM
Asmodeus's Avatar
LS2 chain is more than enough and you won't run into some of the installation problems the double rollers have, and it's probably cheaper. And IMO, you should do the oil pump since you're already in there, but if your car is low mile and the cam will be around the stock rpm range, you could get away without it.
