Thermostat replacement ?
Old Nov 25, 2007 | 12:24 PM
Canuck's Avatar
Default Thermostat replacement ?
I have to replace the tsat on my 02 SS. Is the stock one 187F degrees (same as the one I bought at a local store) and do I drain the rad to change it? Anything other advise is appreciated.
Old Nov 25, 2007 | 12:26 PM
bene's Avatar
Trunion King
You have to drain the fluid out and might I add go ahead and replace the fluid with a new one.
Old Nov 25, 2007 | 01:37 PM
BriancWS6's Avatar
The stock thermostat is 195, and it is the complete housing all-together.
Old Nov 25, 2007 | 02:03 PM
Soul TKR's Avatar
normally i'd say pick up oned of these
http://www.mphparts.com/mm5/merchant...t_Code=09-1014
but seeing as your in Ontario I'd probably go with at least a 180 t-stat
Old Nov 25, 2007 | 05:23 PM
massls1guy's Avatar
I recently put in a 180* hypertech. It's getting cold here, so far so good with engine temp and the heater works good.
Be careful about purging the air from the coolant when you refill the system. The hypertech came with detailed instructions on how to do it. Basically take your time and make sure all the air bubbles are out.
