Help mom w/ car
Old Jun 21, 2003 | 04:55 PM
Kev98Ta's Avatar
Default Help mom w/ car
This dosenn't deal with an LS1 sorry, but a 91 Corrola. My mom asks me 2 look at her car and when i started it the engine immediately revs to 2500rpms then down to 1500 rpms, with a nasty ratttle as it decelerates. Dosen't stop doing this. Anyone w/ suggestions as to what it might be? Afraid to drive the car now. Thanks for your help.
Old Jun 22, 2003 | 06:43 PM
1999_SS_M6's Avatar
Default Re: Help mom w/ car
could be a broken valve train component.. possibly a spring, or a rocker shaft. Had something very similar happen to a friend's hyundai. you might try unplugging each wire from the spark plug to see if you can isolate the cylinder that isn't operating properly. just listen for a different sound from one cylinder to the next. unplug the wire, then start the engine, listen, shut if off. Then, replace that wire, remove the next one, start engine and repeat till you are done..
or, if you're feeling squirrely, pull the valve cover and have a look.
good luck
Old Jun 23, 2003 | 01:41 PM
robertbartsch's Avatar
trade it in and buy an LS1...
Old Jun 23, 2003 | 02:31 PM
trackbird's Avatar
look for carbon around the throttle body and make sure the butterfly closes correctly (and all the way), then check the idle air control valve for carbon deposits under the valve (you'll have to remove it to look, if you find carbon, use carb cleaner and a popcicle stick...nothing metal, to clean it out). Just my thoughts.
Old Jun 23, 2003 | 02:50 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Maybe you need to clean the idle motor or the EGR?
