speed pro pistons
Old Nov 27, 2007 | 03:43 PM
midnightws6m6's Avatar
Default speed pro pistons
does any one know if speed por makes forged pistons for ls1 ive looked and i cant find any
Old Nov 27, 2007 | 04:06 PM
DONAIMIAN's Avatar
Check scoggin dickeys website.
Old Nov 30, 2007 | 09:48 PM
helicoil's Avatar
Default Speed Pro
L2621F 3.897" bore x 3.620" stroke 1.328" CD 1.5mm, 1.5mm, 3.0mm
flat 2 valve reliefs
L2640F 4.00" bore x 3.620" stroke 1..328" CD 1.5mm, 1.5mm, 3.0mm
There was also a couple of part numbers for a 4.00" crank
LW2625F 4.00" bore x 4" stroke 1.125" CD flat 2 valve reliefs 1.5mm, 1.5mm, 3.0mm
LW2624F 3.897" bore x 4.0" stroke 1.125" CD flat 2 valve reliefs 1.5mm, 1.5mm, 3.0mm
Not sure if the latter are available
Old Dec 4, 2007 | 11:47 PM
RUNIN11Z's Avatar
Default Speed Pro
Make sure you look at the pin dia. Believe me there is a difference....
Old Dec 5, 2007 | 04:31 PM
JPH's Avatar
JPH
L2621F & L2640F should be for stock .944 pin. all others are .927 pin.
