ses code after cam install
Old Nov 27, 2007 | 10:37 PM
silverLSWON's Avatar
Default ses code after cam install
i just installed a 224/228 114+4 lsa and stock ls6 heads on a t/a. the car was tuned but i keep getting a p0300 multiple missfire code. i hooked the tech 2 up to and i get a few missfires from each cylinder at idle but none when hitting the gas. even when i ease on the gas pedal, not a single missfire. i'm sure this is common after a cam swap but i don't know if the code needs burned out through hp tuners or if this means there is an engine problom. the car runs freakin awsome. so should i just elminate the code or.....????
Old Nov 27, 2007 | 10:39 PM
MM98's Avatar
Yup very common, just delete the code.
Old Nov 28, 2007 | 01:03 AM
5w20's Avatar
thats normal
Old Nov 28, 2007 | 01:21 AM
soontobeLS1's Avatar
yup normal, had that here too...my tuner just turned the misfire on a low setting...no probs since.
Old Nov 28, 2007 | 09:06 AM
ok thats what i thought, i tried a search but i couldn't really find anything. thanks for the help
Old Nov 28, 2007 | 09:11 AM
BIG_MIKE2005's Avatar
Yep, I keep popping that code too until I can get it completely turned off. I also get a improper O2 heating code now that I never got before the cam swap. Both are normal & won't hurt anything.
