Unknown year ls1
Hello, I've got a ls1 pull out here sitting in the garage and am not sure what year it is. I was told there are some numbers by the oil filter area that will determine the year? How many digits is the number supposed to be? Is it on the aluminum part of the plastic part?
Would appreciate any help
on the heads a bit below the coil packs there should be a 3 digit number..... if 241 most likely from 01 02 853s 99 00 805s i believe correct me if im wrong on the casting is from a 98!
Here is a list of a few casting #'s:
806 97-98 aluminum 5.7
853 99-00 aluminum 5.7
241 01-03 aluminum 5.7
243 LS6 aluminum 5.7
852 and 706 99 and up 4.8-5.3 truck heads
873 99-00 LQ4 6.0 iron heads
317 01 and up LQ4 6.0 aluminum heads
035 02 and up LQ9 6.0 aluminum heads
Even more info:
Casting Number 241
Head: 1997+ LS1 5.7 Litre Passenger Car
Material: Aluminimum
Part Number:
12559853 (1997-98)
12559853 (1999-00) (not sure why same PN)
12564241 (2001-03)
Combustion Chamber Volume: 66.67cc
Compression Ratio: 10.1:1
Intake Port Volume: 200cc
Exhaust Port Volume: 70cc
Intake Valve Diameter: 2.00 inches
Exhaust Valve Diameter: 1.55 inches
Casting Number 243
Head: 2001 LS6 5.7 Litre Passenger Car
Part Number:
12564243
Combustion Chamber Volume: 64.45cc
Compression Ratio: 10.5:1
Intake Port Volume: 210cc
Exhaust Port Volume: 75cc
Casting Number 706
Head: 1999+ LR4 4.8 Litre Truck
1999+ LM4 /LM7 5.3 Litre Truck
Part Number:
12559852
12561706
Combustion Chamber Volume: 61.15cc
Compression Ratio: 9.5:1
Intake Valve Diameter: 1.89 inches
Casting Number 373
Head: 1999-2000 LQ4 6.0 Litre Truck
Material: Cast Iron
Part Number:
12561873
Combustion Chamber Volume: 71.06cc
Casting Number 317
Head: 2001+ LQ4 6.0 Litre Truck
Part Number:
12572035
Compression Ratio: 10:1
Even more info:
Casting Number 241
Part Number:
12559853 (1997-98)
12564241 (2001-03)
Casting Number 243
Part Number:
12564243
Casting Number 706
Part Number:
12559852
12561706
Casting Number 373
Material: Cast Iron
Part Number:
12561873
Casting Number 317
Part Number:
12572035
I have a 98 TA but I know by block is a 97. Mostly because my car says it was built in 97 but when I started my cam swap and pulled the water pump there was a round raised number that said 97 on it. I am not sure if they stopped doing that but if that is on all the blocks it would be an easy way to tell. The number was beside the front cover right under the driveside head.
