list of Clevite bearing suffixes
H - High-Performance
HD - High-Performance bearing with dowel hole
HK - High-Performance bearing with moly/graphite coating
P - Standard Clevite 77 tri-metal bearing
N - High-Performance Narrowed for greater crankshaft fillet clearance
HG - High-Performance full angular grooved bearing
V - High-Performance with Lead Indium overlay (On Main Sets this indicates partial groove also)
VG - High-Performance with Lead Indium full angular grooved bearing
D - Bearing has a dowel hole
K - Tri-Armor coated bearing
X - Bearing has .001 more oil clearance than standard
XX - Bearing has .002 more oil clearance than standard
A or AL - Indicates Aluminum bearing material
and of course there are combinations of suffixes as well...
HN...HNK...HNDK...HXN...HXNK
so they replaced them with the "HN" that will work well with both stock and aftermarket crankshafts...
makes sense, but I thought everyone here ran "H" rod bearings on stock cranks
The mains are still available in "H"
Also before "CLEVITE 77" there are letters N, H or P - do they mean anything?
