LS1 4 inch bore?
Stock crank is 3.622 and you can only offset grind maybe .200 so can't get to 4.000 stroke.
Give them a call. They can help you on the bore. You would have to get it resleaved to an all bore block, in order to get a 4.0 bore.
Yes, you can offset grind the crank to get more cubes. 3.72 will be your limit on the stroke, with the stock crank.
http://www.aera.org/tech/cube_calc.html
.7854 x 8 x Bore x Bore x Stroke = cubic inch
If you need pistons give me a call or you can call one of our dealers like Thunder Racing, LG Motorsports, Futral Motorsports or Agostino Racing.
Thanks,
Chris Gelineau
Diamond Pistons
877-552-2112 toll free
<small>[ February 03, 2003, 11:20 AM: Message edited by: DIAMOND ]</small>
MTI 427 C5 Roadster,
ps-Diamond Pistons-That is by FAR the BEST AND EASIIEST FORMULA i have ever seen for figuring out CID of any engine! <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
