Traction control switch
Old Dec 1, 2007 | 12:54 AM
veloxetmortifer's Avatar
Default Traction control switch
I have a 2002 Z28 and I can't figure out if I have TCS or not. I have a female plug thats not connected to anything in the stereo compartment. Can anybody help me find out if my year car has the TCS option and if so, where cn I find the TCS switch. Thanks for all your time and your help.
Old Dec 1, 2007 | 01:00 AM
trans_am_31's Avatar
When I first bought my first ta back in 2000, I was asking the same question you are. Even though there is a female plug back there, your car may not be equipped with it. I went out and bought the switch at a GM dealer, and I installed it. It hooked up fine and even the TCS (in your case ASR) lights turned on however the light indicating it was functional didnt. So, I found out that I didnt have it. Hopefully someone knows the code on the door for the traction control option. Good luck!!!
Old Dec 1, 2007 | 07:46 AM
Here, I found the code you need to look for inside on your drivers side door.
NW9 ASR Traction Control
Old Dec 1, 2007 | 10:54 AM
RZRSEDGE's Avatar
You'll have a motor that the throttle cable hooks to under the hood if you have traction control. If the cable just runs straight from the firewall to the throttle body = no traction control. Hope this helps.
Old Dec 1, 2007 | 11:10 AM
SSkillz's Avatar
Yea if it the cable just runs stright to the throttle body and not to a little box then you dont have tcs. open your hood take a look
Old Dec 1, 2007 | 11:44 AM
SOM02WS6's Avatar
I would guess that you dont have it. Why would someone take the switch out and then fill the hole in the dash?
Old Dec 4, 2007 | 10:59 PM
Thanks for all the info. I really appreciate it.
