Cheap LS1 stroker crank?
Is there ANYONE who makes a cheap/cheaper stroker crank for the LS1 than Lunati?
I would like to go with either a 4" or even perhaps a 4.25" stroker crank but the only ones I can find are the $2700 Lunati cranks
I'm not looking for max hp here so even a good quality cast crank would work (probubly 650 max engine hp and under 6500 max RPM).
Thanks
Thanks
I've been considering the same thing,,,,
...apparently, all after market cranks are forged billet and that is why they are so high priced...
...i wish someone would make a plan old nodular iron stroker crank since my engine is not for John Force's hot rod...
theres a place in Austrailia that was gonna make nodular cranks...any stroke.
Could you use the factory rods with a stroker crank?
7 Second Club
From: Grove City Ohio/Port Washington L.I sometimes
Callies, Scat, and Cola to name a few ....there was even a lunati stroker crank for $1750 or so in the sponsor forum...might still be there.
Go to page 8 of the price list.
We have 3.822 off-set grind cranks in stock, and 4" cranks also
Jason
Jason
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
Jason
Jason
