Most aggressive cam with no lope?
What's the most aggresive/biggest cam I can put in without being detectable by listening to the exhaust? The pistons can be notched since they will be aftermarket. I am going to use 3.90 gears and a 7K rev limiter (even if peak is 6500).
Thanks!
I'd be careful generalizing LSA as creating "lope"
Turbo buick LC2 camshafts were 106 LSA from the factory.
Our SI-Torque cam for the trailblazer SS is 111.5 LSA yet has negative overlap at .050" not a hint of lope.
Generally yes a tighter LSA Generally has more overlap more lope.
